Milling Tabs and milling direction
Hello, I am new in this.
Very nice Program :slight_smile:
My problem:
If I use milling tabs, the milling cutter is driven up to the max. Z and, to top it all off, it is also driven in again at another point. It would be enough if the milling cutter was moved to the height of the tabs and then back to the original height after the tab.
See the kmz-file.
What am I doing wrong ?
I know there is a another post, but it doesn’t affect my problem.
Thank you for your Help.
(kmz-file: https://drive.google.com/file/d/1qA9LZnxel1lXCLUqmNniEzdDnFMw6UJA/view?usp=sharing )
Ok, i found a post with the same problem from june 2022.
Too bad, seems to be a difficult problem in the code.
