Aligning laser cut slices
Loving the ease of making slices for laser-cutting - thanks so much for the tool! But I am struggling to get the slices aligned. Is there a function so we generate an outline on the bottom piece so we know exactly where the next one goes, e.g. like this:
i.e. blue would cut, red would score, and we could use the scored lines to align perfectly the next layer.
thanks!
-mak
Hi @mak and welcome! Can you do something as simple as add one or two pin holes that goes through the entire stack?
Thanks @stewart. Yes, but it would require a lot of pinholes for anything more complex, such as
and I think I’d lose track of which pinhole went where.
The previous slicer I used was a now-defunct plugin for Fusion360 which had this function built-in, and I didn’t realise how important it was until I tried making a topographical map without it!
oh, wow. totally makes sense for that :slight_smile: let me take a look at the code and see if I can whip something up. the easiest way to do this is with SVG colors, if you’re using that output.
Awesome, that would be amazing. Colored SVG is perfect
@mak I didn’t forget about this. the latest dev release 3.1.D7 has a new option under output
Screen Shot 2021-12-07 at 7.31.58 PM
for a model like this
it adds a different color mark so you can enable a different laser power for marking stacks
Amazing! Can’t wait to try it out. Thanks so much!
Hi @stewart - thanks again for adding this facility. I wrote an instructable on it, see Pending Review - Instructables
awesome. I assume you’ve confirmed it works then :slight_smile:
Like an absolute charm
How can I get this output?
This image before preview
image|267x275
use the arrow keys to rotate the object to lay horizontally
I mean 3D DXF output rather then a a flat layout as in the following
3D DXF output is not supported.
Is it likely to be implemented? Incidentally I had taken dxf out put of CNC mill and following was the view
BTW I am unable to open dxf out put of laser cutting layout.
I tried to online convert ‘workspace kmx’ file but no luck.
Thanks for your quick response
cnc laser output is just gcode with laser on/off commands. can you point me to the 3D DXF spec?
