Hello, I’ve been using the KiriMoto app for two years, and it’s great. I wanted to ask if it’s possible to add milling in the Y-plane to the lathe function. Thank you.
Can you provide and example of how this should work?
Hello, when I turn on the indexer, it displays the beginning of milling in the X-axis. I would like to position the fourth axis on the edge of the table so that the milling machine moves in the Y-axis
Would swapping axes in the gcode suffice? Check out this link which shows how to remap axes in the gcode header. Scroll down to AXISMAP. Example:
;; AXISMAP {"X":"Y", "Y":"X"}
Thank you for the advice, but I believe the command will work for 3D printing. I use Fluid_Nc, and that command doesn’t work there. Thanks.
Ah. I can port that feature to the CAM gcode post-processor.
That would be great. Thank you very much.
Hello Stewart, I tried it today and it works great. Thanks a lot.
Great. I’ll back port that to 3.9 this weekend.
