Thanks for this resource first of all it is an incredible tool.
I teach engineering at a highschool and would like to use this as our 3D print workflow. I have a couple different lulzbots that we print to and I would ideally like students to be able to slice models right in OnShape and then send it to repetier server (havent tested repetier yet).
I have some questions around setting class level parameters where students can only select our three different printers, chose from only a handful of profiles and then generate the G-Code.
I found the hot-key “U” in the documentation that will generate a code that saves the profile in my local browser - but how do I set up this printer / profile on a class level? And can I do it in onshape as well?
Do I need to create hyperlinks for every printer / profile and have the students just click that opens the specific printer/profile?
