I get a blank white screen when i try to export the gcode and am forced to reload. Not sure what is happening.
Hey Daniel. Are you able to email the .kmz workspace (Files → Export) to [ sa at grid dot space ] or DM it to me on the Discord server?
Just sent the file, thank you!
perversely, rendering the preview is causing the browser to run out of memory. the workaround is to use line rendering instead of 3d path rendering. it uses a fraction of the memory and allows the preview/export to succeed. fixing this is really hard for large models. but it’s on my list of things to work on.
