What is the correct way to do a bevel to an edge when generating a CNC job?
For designs that have a chamfer I normally use the trace function and change the tool head to match the chamfer angle I require which works OK,
I have a model that is a rectangle with 2 opposite sides beveled and the 2 other sides not, if I try and use trace and select the side I want to bevel it wants to do all sides.
What is the correct method for doing a bevel?
Currently I am thinking my options are to edit my model to change the bevel to a chamfer or to edit the Gcode directly
Screenshot below
