Trouble processing Onshape CAM
Hello! I am working on my first project in both Onshape and Kiri:Moto. Impressive stuff. Thank you!!
I have been experimenting on a plywood flat pack project with some Cabineo connectors. I have successfully cut some small tests. But now that I have moved to larger nested sheets and I seem to be overloading things. Is there any guidance for performance?
I have been playing with it for a few hours and figured I would I ask here. have attached my file.
Thanks!
-marc
stringers.kmz (756.0 KB)
your pocket operations are triggering a polygon offsetting error I’ve never seen before. it will require some digging.
Interesting. They are generated by Onshape. It is my first Onshape project so it is probably a mess.
Also I am using both a Trace and Pocket. The expand in Pocket works great but in the preview the Pocket looked a little shallow so I added a Trace.
