Trace Error in 4.6.2
Seems like outline got pretty changed in the refactor, so I tried to cut some sheet aluminum parts with a trace op, and the path routing is having an error
trace-error.kmz (812.4 KB)
did it get fixed seems to work ok for me
workspace_merged.kmz (400.5 KB)
I see the bug. thanks for the workspace.
you have skip shadow enabled which is preventing the path from using geometry for routing.
