Are there any scripts for tool change? I am lost and cannot find how to set up? I assume go to a certain spot, raise z and change tool. (assume) bad word…then return to previous position.
Tool changing is typically up to the controller / sender. So when it sees something like “M6 T1” it knows what to do. That’s on more sophisticated controllers, usually.
If your machine does not have a tool changing mechanism, then you’re better off using the zip export option that puts each tool/operation in its own file. then you just run each one separately and handle the tool changes manually in-between.
Thank you sir! Learning curve rather steep.
