The Rough toolbar extends into the kiri header when using kiri through onshape and stand alone version and tool selection and step down are inaccessable. I’m on a Acer R11 Chromebook (11.6" display probably 16:9 ratio, if that helps) using the Chrome browser. I can switch to full screen mode and the problem goes away
Hi @weatherdan and welcome! Thanks for the report. I’ll look into a way to correct for this. At the moment, the popout is positioned with the midpoint at the cursor.
@weatherdan Actually, that was an easy fix. Should be live now. Just shift+reload your page.
Thanks for looking into that!
