Today I took the time to try to configure for 3D printing but I have problems.
First when importing and slicing an object, I get stripes after slicing. The pictures shows it all.
Then I tried to add automatic support but nothing is happening (well it did in the first model but not when I choose to reload it). It’s also impossible to tick the support box.
The menus on the right hand side behave strange, at least in Google Chrome and sometimes I can’t make edits.
When clicking to change values the default value doesn’t disappear so I have to either use the backspace or delete keys (depends on where the cursor is landing) to remove the digits before I can input new value. If I simply klick and try to insert a new value the old value is still there.
I found out that tabbing through the menu works as intended but not a simple click in the value box in spite it’s yellowed (for editing) the new input is added and the old is still there so one must fiddle with the bs/del-keys.
When clicking on a section a menu pops up but when I move the mouse a bit is close itself. Isn’t it better to just have pop-up menus instead of have to click on every single menu that then disappear by itself after 2 seconds?
No, i’m not the grumpy old man
