Spiral Outline?
I know this feature from CamBam. Instead of plunging vertical into the material with every step down, you can select “spiral”. Then the tool path will slowly go down until it reaches step down after travelling the outline once.
Advantage:
No vertical plunges into the material.
Disadvantage:
Reaching the bottom it needs to travel the outline once more on bottom level.
There is an option called ease down under the output menu that approximates some of this. it doesn’t work in all cases.
Yes, I have seen the ease down, but it does not make a difference here, unfortunately.
