I don’t think so. Just ran that - and in both cases the rotational axis is 90 degrees off from the default setup on the machine. But it’s just bolted on, so I can easily just turn it. Don’t see a way in KM to specify the axis of rotation. Thanks again!
you could use the same axis map to swap X and Y if that helps
OOOH. Of course. So sick. Thanks!
