I have noticed that when I slice a project it freezes or takes forever to do so. What would cause this and are there any settings I need to change? I am using Microsoft Edge if that makes a difference.
BTW, I performed my first 2.5d carve and it worked excellent thanks to the advice of downloading the zip file.
If you right-click export your workspace (produces a .kmz
file) and drop it here, DM or email it to me, I can diagnose your exact setup.
vevor_3018_pro.km (5.8 KB)
Let me know if this is not what you needed. Thank you so much
That’s a device export. I need the entire workspace. That file will have a .kmz
extension.
Hello Stewart
I did trial and error and the thing I came up with I checked the shadow mode in this expert box. This seemed to do the trick. Thank you so much
Ok, still sounds like a bug. So if you can provide the workspace the triggers this, I can track it down and fix it.
