Slicer crashes at early stage (<10%)
I hope I can attach the workspace file.
Slicer crashes in a very early stage… ( <10%)
regards,
NPu
can you share a google drive or drop box or other link?
Here is dropbox link
When i tried to scale down the object, slicer was OK. Size matters??
regards,
NPu
Error code: out of memory!
But from windows task manager I did not see lack of memory. Is there any setting in Chrome browser which define this…??
thanks for the workspace. I’ll look into this. it should not be crashing with this model.
there is a fix on the dev server if you want to test there. support generation is taking a long time (4 minutes) but works.
Hi Stewart,
Unfortunately it is still happening.
Anything I need to improve with my chrome ??
regards,
NPu
I pushed another set of memory optimizations to the dev server. shift + reload or try in a private browsing session.
Hi Stewart,
Slicing large object is still failing with the same error code.
I noticed this problem when hollow_shell or support is used.
regards,
NPu
Hi Stewart,
I have been using the slicer since you updated. It worked better with large objects. Only the supports are standing too close to the object, and it made they were sticking to the object sides.
regards,
NPu
