I searched around but could not find an stl or stp of the Simple cube model. Is it possible to get one? I wanted to use it to compare different slicers and speeds to KM.
attached are a simple cube (solid) and the sample cube (kiri default open model). the sample cube is included in the source on github and you can also get it by opening Kiri in a private browsing mode window then exporting the default model on the platform using the mesh menu.
simple-cube.stl (684 Bytes)
sample-cube.stl (15.7 KB)
Thank you I meant the default sample cube… not sure why I typed simple…
I will take a look at the GitHub repo.
I attached them above to save you the time ![]()
