Hi again
I can not set my start point, in Kiri Moto. “set zero in my gcode sender”, It seems to set where ever it wishes?
thanks
Edit, Oh I think it is just the animate view in Kiri Moto does not show animation from the starting point. I opened it in another viewer and it is different.
the starting point (0,0,00 is where the origin is. you can turn that visualization on in preferences > display > show origin. and control it through the origin control panel on the left.
I have that set to top. I see the origin. Will it will always be set also to my z clearance?
In another it looks to be starting below the clearance. I will just put it in the machine with out stock.
thank you again
you’re in control of the zero point on your machine. the first entry point in the job should be at origin + z clearance. try playing with limits --> z anchor to see if this affects the starting point.
