Rough then Pocketing: air cuts
Maybe this was addressed in a post I saw back from December '22 and is still in the works:
If I perform a roughing operation followed by a pocketing operation, the pocketing operation results in a lot of air being cut where the rough op has already removed material. While the part machines nicely in the end, there’s a lot of time wasted on the pocketing cuts.
Here’s a simple part to demonstrate, if needed.
Pocketing Test.kmz (433.9 KB)
And thanks again for making and maintaining Kiri:Moto!
-Jesse
At present, KM does not keep track of material removed between ops. “rest machining” is on the todo list.
