In the future will you be able to incorporate the Rest function as seen in Fusion 3d.
Example is one tool cut’s out an area and the next tools cuts out the “Rest” that is left?
fusion define it as" The rest milling operations allow the user to perform machining only in areas where there is unmachined stock material left after previous machining operations . It is also possible to machine remaining material after ‘virtual’ machining performed using a user-defined list of tools."
Hi @Carl_Olsen … yes, this is on the roadmap.
