This release had a few twists and turns. While laying the ground-work for 4-axis milling, the Carvera showed up and I took a detour into mobile improvements and laser pathing. So it ended up being a mix of CAM + Laser and mobile updates with a major update to CAM animation.
The 4th-axis work is now slated for 3.7, which might be slightly more disruptive. I didn’t want to hold these improvements while that stabilized.
Details (from release.md
- add new Carvera machine target in CAM mode with laser support
- add laser output operators and device settings in CAM mode
- add fullscreen option. button next to user profile
- mobile pinch zoom and layer slider usability improvements
- update CLI to work in CAM mode and add working samples
- improved FDM preview rendering speed and reduced memory usage
- threaded task and message passing performance improvements
- refactor FDM supports and synthetic widgets to use more common code
- allow FDM mixing of automatic and manual / detected supports
- improve CAM animation speeds using shared array buffers
- improve CAM render quality using solids instead of lines
- add CAM leveling part offset parameters for XY and Z
- add CAM pocket smoothing and contouring which is closer to true 3 axis
- add CAM 3D engraving and marking with the pocket contouring operation
- fix CAM invalidation of tabs on scale and traces on scale or rotate
- fix belt fan override for base extrusions touching belt
- fix belt X axis label order
