I wanted to know if using trace in this way would mark the four holes. See workspace attached. If not is there a way to accomplish the hole marking using the setup described below.
I’m using an X-Carve CNC Router with a 1/4" Round nose bit. X-Carve does not change tools so it has to be done manually. The issue, loosening the collet almost always moves the X Axis. Therefore X and sometimes Y position is lost.
I use the 1/4" round endmill for stiffness.
Marking these locations would be nice to drill post process.
workspace.kmz (597.4 KB)
