Possible to control the order of outline cuts?
Hello,
Newb here. I’m cutting carbon fiber sheets in a water bath. I have the sheet elevated from the bottom of the bath using standoffs. Unfortunately though, the outline cut that I’m using has ordered cuts such that on the final cutting depth, the boundry of the workpiece is cut first and the work piece sinks to the bottom of the bath before the interior cuts are finished. What is the way around this? Can I order the features the Outline tool makes?
Thanks,
Aaron
I expect the right solution to this is tabs.
Of course, you can also do manual post processing to re-order the cuts the way you want them.
Thanks @jsiddall . I forgot to come back and report that i figured out a way. 2 steps of “outline”, the first is all “inner only” and the second is “outer only”.
