Hello folks, this seems interesting. I have some panels for which I’m using KM to generate a canned cycle. If I only use a roughing cut, all is well; however, upon adding an Outline step, running “Preview” results in a hung program at this step:
One other note on the bug. With the outlining options selected, it was going to end up doing nothing anyway. It just wasn’t gracefully handling this case.
Stewart, correct me if I’m wrong, but my impression is that none of the current passes have any idea what might or might not have been removed by a previous pass. Am I right about that?
That’s correct. If I recall, the outlining operation had “outside only” checked which means it will only cut areas that pass entirely through (or around) the part. So it had nothing to do.
all operations are computed independent of each other. but the purpose of “leave stock” is so that an outlining pass can slowly or more neatly remove the remaining material. outlining can then have multiple purposes with cleanup and cutout being only two.
