Sorrry, i m sure im doing something wrong …
Unable to pocketing the areas (blue color)
attched the link file with the job itself … (stl format)
Metric dimenssions, diameter of the cutting tool 6 mm …
I need help …
THANKS in ADVANCE …
I need help …
THANKS in ADVANCE …
please right-click export the workspace to produce a .kmz file and message it to me or drop it here. best to upload it to a file sharing service first and just send the link
SALUDOS !
Previous problem, solved using FIREFOX instead CHROME …
here the kmz file …
after doing allot of tests changes and experiments … KIRI MOTO writes a GCODE file with some errors (some points outside the router AREA) …
Maybe the change that really worked is the adjustment of the parameter tolerance, setting the tolerance to 0.1 at least the program wrote something and after correcting manually the points i get a GCODE file…
If pocketing fails (the program freezes) maybe adjusting the tolerance can help …
REGARDS and THANKS
Worked well wit this geometry !
THANKS and REGARDS !!!
