Pattern Registration for Double-Sided Milling
Based on a link @Bruce sent to me showing a clever way to do double-sided milling, I incorporated the feature into Kiri:Moto’s registration operation. Take a look at the video to see how it works. This is live now in the 2.6 development version.
That is clever! I presume the thickness of the steps corresponds to the diameter of the tool so you still have a tight fit after the flip?
The step size is somewhat orthogonal to the endmill size. Geometrically it works out to be a perfect fit (zero offset or overlap) if you flip it on either axis.
Is there a way to prevent flipping it on either axis? If, say, you only wanted it to ever be flipped on just one?
like a system preference that hides the Y axis option? the current geometry both allows flipping on either axis, but necessarily must allow this to work.
Might a pattern like this be a solution for one axis flipping?
that would still allow flipping on either axis, but would be less secure when pressed back in place.
Thanks a lot works like a charm!
I was going to suggest the same. While it would not make it impossible to flip the wrong way, the wrong flip would be obviously wrong.
I added a new axis mode “=” to 4.4 on the dev server that notches the bottom cutout tags. then you know exactly which orientation it was cut in. just flip those tabs to the top or if you flip on Y the notches move from left to right.
