Hello,
I have placed some tabs on the workspace, but slicing it ignores and cuts through the tabs.
Only the bottom-right piece tabs are respected. The rest are ignored. I have disabled some of the pieces until leaving only one, but if the tabs are placed in any place but the bottom-right piece, they are ignored.
Any idea what I am doing wrong?
Thanks!
workspace_tanca_h_01 (1).kmz (564.4 KB)
this appears to be a bug where tabs are all assigned to the first object on which a tab is placed. the workaround (for now) is to merge the objects then add tabs to the merged object. the merged objects are treated as one even though they are spatially separated.
this should be fixed on the dev server now. please test and let me know. thanks
Thanks Stewart! I will test it next weekend and let you know.Dev server? Is it in a specific URL?
Hello Stewart.
Apologies for the delay but I have been able to check dev server only today. Slice operation looks fine with all tabs added to the outline operation.
I will be able to put it working in 2 weeks.
Thank you!
