Operation to engrave text
I want to engrave text. It seems that the basic function can be done with a pocket operation. However, for a small amount of text of around 60 characters, it is necessary to do hundreds of pocket selections. Am I missing something? Should I be using a different operation? Are there any instructive videos?
if the bottom of the text is flat and share a Z height then you can use trace and ctrl + click the bottom edge of a letter to select all letters. then use trace + clear + step down instead of pocket
Thanks. I am making some progress.
