Onshape Kiri:Moto App: I noticed when routing out a 2.5 inch cylinder the mesh density is insufficient for a smooth outer surface. I can feel the ridges after route. The mesh check has 814 faces. Gcode File size ~12,000.
Saving the OnShape to an STL file using the “fine” quality setting is better. Loading the file into Kiri:Moto browser tab results are better. 1956 faces & GCode File Size ~18,000.
Is there a way to specify in OnShape the mesh quality?
After experimenting with the Preferences. Decreasing OnShape Angle preference improved results. Not sure what Angle & Chord actually do. Would you explain?
The Chord is the distance between points on a circle.
The Angle is?
