Having just recently started to try using Kiri:Moto as a slicer, I’m working on calibrating the filament flow and I’m running into an odd issue I’ve never seen before.
When measuring the walls of the test print, the right side (if you’re facing the nozzle) under-extrudes by about 17%. The left side and “top” of the print extrude at 0.6mm, but the right side prints at just shy of 0.5mm.
Has anyone seen anything like this before in their prints?
