Hi
I’m having a lot of difficulties generating a complete gcode for cutting a specific part. There are “uncut” areas. I’ve tried playing around with different settings.
The problem realy is in contour cut, and fails with both axes. I hope you can help.
Im using import from onshape, but also tried directly through the webinterface by importing as an stl.
Here’s 3 screenshot, where a contour is used in Y, (there’s a zoomed picture with some weirdness in the middle, and also a cut in x.
The workspace kmz file is also included: WeTransfer - Send Large Files & Share Photos Online - Up to 2GB Free
Thanks!
