Hi, I’m trying to use the trace function in the bottom of a V-groove, but can’t select the line directly at the bottom of the groove in Versions 3.8 and 3.9. I can select and generate a path in Version 3.7.
I’ve attached a simple example to demonstrate the problem.
Thanks for the test workspace. It looks like I left some code commented out while testing. I’ve got a patch for 3.8 / 3.9 that I will put into production later today that reverses this.
Got the email. Thanks for that. And easy to repro, so I should have this fixed sometime tomorrow. Not sure if I’ll be able to push to production since I’ll be traveling.
workspace tool shelf.kmz (769.4 KB)
I’m having problems selecting edges in Trace mode. I saw the post that said you fixed it, but I still can’t select the same lines that i could select in 3.7. Like on the lower edges of the bevels of the attached model. And the the inside circle on the beveled holes. If I revert to 3.7 all these edges are selectable.
CDO1955
