I have a strange behavior with the level operation. Ah the end of the path, the tool plunges into the wood. As a result, there is a final Gcode with a Z-8.0 (which obv causes CNC problem) command : G0 Z-8.0 F300
This Z coordinate is with a Z clearance = 5. The weird par is that if I change the Z clearance, this list Z Gcode changes. For exemple, with a Z clearance = 15, the final Gcode command is G0 Z2.0 F300.
Same behavior with any tool and any machine. Basic Kiri:Moto configuration.
Any idea ?
Rénald
