I have a part (it’s a classic circle/diamond/square part, for checking my router) which carves fine if “leave stock” is set to 0, but which loses parts of itself if set to something normal like .03 in. I’ve never had this problem with “leave stock” before, so I have a hard time believing it’s not user error. Ideas? (.kmz attached.)
Thanks. Looking at it some more, it seems that the square and circle both get outlined correctly. But the circle outline doesn’t (or, “may not”) take account of the clearance needed for the diamond’s points. And the diamond doesn’t get outlined at all – so either no stock was left on the diamond during roughing, or it won’t be removed during outlining.
just figured this out. the roughing operation has a leave stock option. when the outline operation follows, it does not and it eats into the left material. this presents a false sense that the cut is wrong. it’s just cutting to the final surface dimension. if you reduce the outline step down, you can see this.
I’m confused. Maybe I’ve forgotten the steps. AIUI, I “leave stock” in the Rough pass so that the Outline pass can trim it away. Neither should go beneath the final surface dimension. And yet the tips of the diamond and the adjacent edges of the circle appear to be taken off by a trim that occurs in the Outline pass.
roughing leave stock leaves a larger diamond than the final desired dimension. outline cuts to the final surface but the step down is crude so it doesn’t re-cut the diamond. with a shallow step down on outline it cuts the diamond and there is not “leave stock” tip to be cut.
the proper way to finish this is, after roughing, use a trace or area op to clean up the stock that was left. also, you need to enable clear faces so that roughing does a pass exactly at the z height of each face. alternatively you could do secondary area clearing passes for that. then finally an outline outside only cutout pass.
