Just started looking at Kiri Moto. Created a part and set some tool paths. Using a Larken 24/24 CNC. It prefers the units for its g-code in imperial yet the gcode is producing as metric. Anyway I can set the units to imperial for the gcode? I do have the units set to imperal in preferences.
KM looks at the device’s gcode header to determine output units. so if you add G20 to your header, output will be in inches.
Thanks. Will try that.
