Hi All,
Really enjoying KiriMoto. I was testing out a knife handle design in foam. Not bad so far, needs a finer overlap to give a better result in wood. Hope to show you the wooden version as well. I messed up the material thickness. Hence the large border on the split line.It cleaned up well with light sanding. Uses a 3mm ball nose for everything for convenience. The dimples on the side are where the side rivets would be.
Alan
