I am unable to replicate your slicing bug. I opened your workspace in private browsing tabs on both grid.space and dev.grid.space and was able to slice without issue. do you see any errors on the javascript console?
honestly I’m at a loss as to how that workspace was created. the objects had merged and overlapping and even some invalid geometries. this workspace is cleaned up.
I was thinking might have to do with the cutting one part at a time….and the tabs are only attached to the first item the insert of tabs starts with….duplication of part with tabs worked.
Then I add the tabs, operation and export to gcode. And last step is to open the exported file with Candle and send it to the CNC machine. This process worked perfectly many times during the last months, when I got my CNC machine as a birthday present. Today, after a couple of months without using the machine, I got this strange behavior from KM (maybe me a bit confused after Christmas Eve’s dinner…)
In this specific case, as it went back and forth with @meddesign helping out, I am not sure the transformations that the workspace suffered.
The merge trick worked perfectly. Now my machine is cutting like crazy
By the way, what happened to the Z Through parameter? How do I say the machine to go a bit deeper than my part, to ensure it cuts it completely? Is it with a negative number on the Z Bottom value? If I do this and after that I place the tabs, these are placed incorrectly. I usually did a 2mm Through.
I import the svg with 18mm height. If Z Bottom is set to -2, when I add a 3mm height tab, it is placed at Z= -2mm. 1mm is above surface, 2mm are below.
reset Z Bottom to 0 before placing tabs then set it back to -2 after you do that. this will cause the tabs to be placed on the bottom of the part instead of at the Z Bottom value
Just was cuting a part had to stop before I was done as the tabs were not there….and this was the reason….I will know better next time……lots of tricks to know. Seems like this was not an issue before?
yes, this is one of countless changes. it’s a new degree of freedom when placing tabs. you can also set z tops and bottoms on individual operations instead of globally. those settings do not affect tab placement.
