Thanks for adding the Anycubic Kobra 2 profile a while back.
The only issue I see is that when slicing a medium-large object, when trying to slice on an iPad, KM crashes and has to reload.
Its not a big problem but it happens repeatedly.
Video Link
I’ve found it be able to slice when line type is set to Flat.
Not really a preferable way of viewing but it doesn’t crash as frequently with it.
Glad you found a sort-of workaround. It’s definitely a memory limitation imposed by WebKit on iOS. I can’t fix that. In fact…
This is an Apple problem, the root of which is quite galling once you understand it. Apple does not really allow other browsers on iOS. All other browsers on iOS like Chrome or Firefox are actually required to use Safari’s WebKit under the hood. So they’re just skins. And Safari’s WebKit is hobbled and broken by Apple intentionally.
Full modern web standards can replace 99% of all app store app functionality. So allowing that on iOS would undermine their app store cash cow. As a developer with experience going back 40+ years, developing for Safari/iOS is like developing for the web in the 90s and early 2000s when MS IE was the backward broken thing you had to work around. Only it’s actually worse. You can’t work around most of the things Apple refuses to implement or has left broken. And you can’t install an alternative.
Wow, that’s interesting. Thanks for sharing. My iPad is already limited to 3gb of ram so hopefully future updates don’t slow it down even more.
