I’ve just tried to bring an assembly through from Onshape to Kiri using kiri inside my Onshape doc.
Parts and multi part studios import just fine. Assemblies, nothing.
Is this something Kiri side?
I’ll check, but assemblies should work ok. When faceted, would it contain a lot of vertices? IOW, does it have large curved surfaces, lots of fillets, faces? If so, it could be hitting a threshold I implemented on the server to prevent denial of service.
Hi Stewart, It’s a fairly simple model. The individual parts import ok.
I tested it on a couple of models.
Here’s the link
Hmmm, odd. I’ve tried again using the same settings as your screen shot and still nothing. When importing an individual part it hangs on the import and needs a refresh to display.
I’ll try again at home just to check it’s not some random network issue caused by the colleges security.
