Full docs @ https://docs.grid.space/projects/kiri-moto
Release 4.4.0
General
- add version numbering utility script
- split out help/info menu and language menus
- move install/uninstall/quit menu to center app menu
- add help menu visual callout
- improve language translation coverage
- improve build and serve workflow for alternate builds
- update service worker configuration
- add install/uninstall options in setup menu
CAM
- implement tab hopping - toolpath goes up and over tab instead of interrupting cut (fixes #207)
- add GPU accelerated contouring for faster operations
- add radial GPU raster support (experimental)
- add new register mode that marks bottom cutout tabs
- add curves-only support to GPU contour
- add zsafe and move to safe z at start of new operations
- fix ‘safe’ moves during operation changes to be moves, not cuts
- fix tolerance/resolution for GPU raster mesh calculations
- fix NullPointerException with tabs in contour
- improve merge/co-planar point handling
- add slice layer naming using operation notes (fixes #447)
- fix level step down units (fixes #446)
FDM
- document remain_time macro variable (refs #339)
- re-add base flow rate multiplier for belt mode (fixes #444)
- fix belt fan control ordering (fixes #438)
- exclude belt from bridge fan layer
- add centering feature for fill areas (fixes #448)
Mesh:Tool
- add STEP export capability
- add STEP import with face generation
- improve face generation with inner holes
- add mesh scripting tool and persistence
- add plane and plane.loft operations
- add global edge map and edge reuse for better topology
- add devel device export option
Electron
- clean up electron build process
- merge electron mod into core
- add service routes when available
- set proper content-type for appended code bodies
Dependencies
- update @gridspace/raster-path to latest version with GPU acceleration
- update @gridspace/app-server for proper fallthrough handling
- switch from npmjs.org to git repos for @gridspace packages
- update WebGPU implementation
Bug Fixes
- fix Bambu Lab local URL and module load order
- fix progress reporting for raster operations
- fix GPU lathe progress and contour API usage
- fix tool offsets when using GPU acceleration
- fix indexed rotations epsilon value for accurate zflat calculation
- fix traceload debug option
- sanitize topo3 resolution to avoid GPU floating-point errors
