Issue compound angled parts
Sometimes the version 4.4 aligned face feature does not work….here is 2 workspaces the labeled angle workspace is from a compound angle part in Onshape with one face put flat on the table. It will not find the holes…The workspace labeled true is the same item translated in Onshape and the holes are able to be found……I really like the new feature as all my parts in the wing are in compound angle. Also link to Onshape part studio
workspace_KIRI_TEST_TRUE.kmz (89.6 KB)
workspace_KIRI_TEST_ANGLED.kmz (98.5 KB)
I pushed an update to 4.4 on the dev server that should address this. please verify.
It worked for Angled part….steps are load into V4.3 in onshape….export….import to V4.4 and use arrange tools/buttons.
Thank You
workspace_KIRI_TEST_ANGLEDa (1).kmz (78.3 KB)
