Is it me! Climb and Conventional reversed
Hi,
There seems to be a tiny bug-ette when I try using Rough and followed by Outline, it seems as though Climb and conventional milling settings are not the same in both operations.
Is it me?
Regards
Geoff
workspace_hold_down_clamp.kmz (845.4 KB)
thanks. I’ll check it out. as long as it’s consistently wrong, then you have a workaround :wink:
Hi Stewart,
The problem is consistent and the work around is working fine!
