First of all I would like to thank you for this fantastic piece of software.
It’s the only soft I know which is able to output CNC Gcode from a .stl file. GREAT job done.
I just discovered this tool a few hours ago, and already love it !
I wanted to import a .dxf file to see how the gcode would be for my CNC or my laser. But I couldn’t find a way to import it.
Do I miss something or is it currently impossible to import dxf (which is a standard vector format) ?
DXF is really a set of many different versions of a proprietary format defined by AutoCAD, rather than being a standard. While there is plenty of software that supports various versions of DXF, there are often incompatibilities between them. SVG, by contrast, is a W3C formal standard.
Ah ok, I wasn’t aware that it was a proprietary format !
I will try your trick to use inkscape for conversion to SVG. Hopefully SVG will keep the geometry and vectors!
So I tried to convert dxf to SVG with inkscape : it works provided that dxf is R13 format !
But when importing into KM i get strange result. Seems that KM doesn’t like splines.
So I converted into polylines. But same result.
here is my dragoon :
May be a grouping issue in the SVG. Tools like Inkscape focus on appearance, not CAD ready solids. Perhaps if you try to fill the object with a color, it will force it to properly group the object
I have tried to simplify the drawing to a simple “moon shape” concave polygon.
Here is the shape seen in inkscape and when converted to svg and opened with a browser
And now when imported into KiriMoto
I believe (from what I see) that the problem is possibly when importing concave polygons into Kiri Moto. The svg can be properly open into any browser.
As expected, this is expressed as two arcs grouped. KM sees it as two arcs and extrudes as such. I had better luck using SVG free online editor for your drawings - drawsvg to create a continuous spline with negative space.
