I have a problem with the stock when i loaded my model onto kiri moto my stock adjusted to the model. The problem is that when i loaded a bigger model stock adjusted the size to the bigger model. how ever if i want only my small model into kiri moto how to adjust my small model stock to be the same as big model stock?..
for example my big model is 6 by 6 by 6 and my small model is 5 by 5 by 5 how can i get my only small to be 6 by 6 by 6 instead of automatic fix my small stock which 5 by 5 by 5 can i change it to be the same stock as the big one?..
When i change my preference to mm dose my stock in kiri moto change to mm too?..
under the stock menu (right), uncheck offset and then the stock size will be absolute vs relative to the part dimensions
