Hi, I am running Kiri:Moto 2.6 version in Chromium.
I should mill a really simple object and i wish to use only the rough and the outline operations.
Here the configuration I have for both.
Should not be present also a “line” of “outline” against the pocket wall?
Or maybe am I doing something wrong?
The line will be offset by 1/2 of the tool diameter. Added to that in your roughing operation is a 1mm “leave stock”, which I presume is intentional for outline to clean up
Yes, the 1mm of “leave stock” is intentional. Exactly for this purpose should not be present a “purple” (outline op) line between the biggest black (rough op) circle and the stock to clean out this mm? I think i am missing something.
