I’m trying a new version of my piece, implemented as a separate onshape part.
I can get the new part into the kiri workspace – in fact, I can get multiple copies of it – but I can’t figure out how to remove the extra copies, or the single copy of the original part that I’m no longer working with.
the [delete] key should work on any selected part. the caveats about key focus in Onshape sometimes not working (unless you click an html element like a side menu) apply.
Thanks. Too bad that isn’t (and perhaps can’t be?) in a right-click menu. I would have found it there. Is there anything Delete will delete besides parts? Could Help enumerate those things?
BTW: another inch/mm fixup – Just noticed Alt-arrow in the Help pane. It moves things 5mm, regardless of units preference. Not too important, since one would only use it for rough positioning anyway.
