How to program to square an edge of stock
Good morning, trying to figure out how to program kiri:moto to square off an ege of stock.
Thank you so much for your hard work.
See picture.
do you just want to do one side? if so, use trace in line mode and a dummy cube set to size of stock. select the bottom edge of the stock to square off. if you need a basic cube, i’ve attached one you can scale to fit
simple-cube.stl (684 Bytes)
Thank you so much, keep up the good work, That is what I needed.
