I’m no expert and cnc milling is still a steep learning curve. I’m trying to get a good surface finish on an external surface of a cone in aluminium. I have tried using pocket contour operation with a 6mm diameter round nosed cutter with a10% step over. The cone is 50mm at the base and reduces to 35mm with a 20mm height change.
high rpm low depth of cut….ask ChatGPT AI for speeds and feeds based on cutter diameter and other settings. Tell it you want a good finish….I cut .005 to .010 deep 16000 to 30000 rpm with 1/8 diameter. It will change depending on your tool
