I don’t have a tool changer for Cam operations and I was hoping there was a way to export each CAM operation as a separate file? Roughing in a file by its self. Contours by its self, ETC.
Its very time consuming and can introduce errors doing it by hand.
hi @cdo1955 and welcome! you can ctrl+click or cmd+click an operation to disable it (turns red). then export will ignore it. the feature you’re asking for (a zip download containing a file for each op) is on my todo list.
Thanks for the prompt help, Great software
Just wanted to add: I don’t have a tool changer either, but I setup my G-code streamer (bCNC) to intercept tool change requests so I can manually change tools, then keep going. I find that to be easier and less error prone than running separate files.
maybe this week in a dev (3.2) release… I will post a follow-up here.
turns out this was easier than expected. will be in tonight’s release!
zip file export with operations in discrete files is now in production in version 3.2
I tagged on another feature per a request from @mcdanlj which is to enable/disable parts from consideration similar to the way operations can be enabled / disabled. when selected, the top/left context menu now has delete (trash icon) or disable (x icon). when a disabled part is selected, the (x) turns into a check (
) to allow you to re-enable it.
please let me know if these feature are working for you
Can you share any info on how you went about setting that up? I’m using bCNC as well.
Sure, have a look here: Tutorials: Tool Change with bCNC, FreeCAD & grbl · vlachoudis/bCNC Wiki · GitHub
IIRC I am using “Manual Tool Change (TLO)”
Thank you for the link! I will have to do some reading and testing.
