In this particular case I’m wanting to do a quick pass using a smaller bit to clean up after using a 1/4 bit. A 1/4 bit left nub on the inside fillets. While doing a drill pass using a 1/8 bit I’d like to clean up the fillet without roughing the entire pocket. How is this accomplished?
As a side question, is there a keystroke quick guide? Cheat Sheet? I just noticed “Z” zooms.
workspace.kmz (228.7 KB)
