I get a dialog box to pop up that says " group 0 Files yes or no".
Can you explain what this is about?
What are you importing?
I wasn’t importing. It just pops up. Sometimes when I click on the the object and then off to the side. Sometimes when I’m trying to enter numbers into the data fields on the left and accidently slip off into the drawing field.
that’s odd. are there repeatable steps to induce this? fix should be simple if I can trace it.
Click in the tabs widths box to enter numbers. Then with the right mouse button still clicked drag off in to the main drawing window. The back ground turns green. Try it several times then group 0 Files yes or no box opens up.
This happens to me when I’m trying to highlight a number in the data entry to change it but I accidently pull of to the main field with the right mouse button still clicked.
I mean left mouse button. I also noticed that a copy of the number that I highlighted shows just above the cursor when I pull it into the field.
The TABS box width is set to 4. When i left click on it and drag to the right, the background turns green and the group dialog box shows up.
what’s your browser and OS? I’m unable to replicate this behavior.
Window 10 and chrome
I’m pushing out a change in the next release that ignores phantom “drop” events (which contain no files but may still register as a drop event). hope that helps
Thanks. It was a small issue but it will be nice to have it fixed.
